What do I charge my LOSB9820 7.4 lipo with
Just going down the 1/8 nitro buggy LIPO route
have an 8 2.0 and now the LOSI lipo 7.4v 2S 2000ma
What charger/ balance charger do I use for this as I've read the LOSI balance lead is different plug.
Do I stick Losi and get LOSI 9603 or 9605,
What do you LIPO users suggest.
Thankyou
Thankyou
Super Moderator
Trader Rating: 31 (100%+)
If this is correct "7.4 2S 2000mah lipo", that is nowhere near enough battery to move a 1/8 brushless buggy.
Actually he's referring to lipo receiver packs. Both of those chargers will work for a lipo receiver pack, but otherwise any lipo capable charger from any manufacturer will be more than sufficient. But also you should keep in mind depending on what you use for servo's and receivers, you may need to use a regulator.
Super Moderator
Sorry my bad
Hi,
I have the losi regulator to limit to 6v
I also have ace servo's and a spectrum rx
I believe these may well work direct from the lipo, without the regulator but will use thr regulator first to see how it all performs.
I thought the balance lead on the losi lipo had different connector hence why you need a losi charger/balancer
Cheers
Cheers
The losi receiver pack uses the most common balance plug around so no need to stick with just a losi charger. Oh and just so you know the spektrum receivers can't take an unregulated lipo, so its good you have the regulator!!
I use a Triton EQ with a squid attachment. Best charging solution I could find for a Nitro guy.
The Squid will connect to everything I have, and the Triton EQ will power my NiMh hump packs, Lipo receiver packs, Lead starter box battery, and my NiCd batteries in my glow plug igniters. (The squid even has a connector for glow plug igniters.)
If you run electric vehicles too, there is a Triton charger that is one more step up and it's power supply will keep up with large lipo packs all day long.
