-   -   Novak GTB sensor wire (https://www.rctech.net/forum/radio-electronics/298020-novak-gtb-sensor-wire.html)
meon99 05-18-2009 11:00 AM
Can I run my GTB with different sensor motor besides novak like LRP, Orion, Tekin? Do they share the same sensor wire like using the same wire for different brand motor? Thanks.
Also, which ESC can run both sensor BL and sensorless BL motor? Thanks again.
rcterp 05-18-2009 11:08 AM
Sensor wires are universal. You can use the GTB with any sensored motor you want.
Castle and Tekin are the first two that come to mind for sensorless and sensored use.
meon99 05-18-2009 11:11 AM
So I can use the Tekin sensor ESC like the RS or RS Pro with the sensorless and sensor BL motor?? Thanks.
rcterp 05-18-2009 11:16 AM
Sure can.
meon99 05-18-2009 11:26 AM
Originally Posted by rcterp (Post 5827925)
Sure can.
nice..
Foxxrocket 05-18-2009 02:02 PM
Yep. I have a Novak Brushless motor with a Tekin RS Pro, and a Trinity DUO with a Novak GTB. They works just as good as their associated counterparts.
dgrobe2112 08-05-2009 11:31 PM
novak gtb 7.5r velocity esc and motor. can i use it with orion vortex 8.5?
racer1812 08-06-2009 05:53 AM
:nod::nod::nod:
dgrobe2112 08-06-2009 07:09 AM
well, i wired up my new VORTEX motor, and it made about 10 seconds, and poof.. i didnt do anything different, made sure the wires went from A to A, and B to B, and such, i had to use the provided sensor wire from orion, but i made sure that it was all plugged in right. put it in the car, ran bout 10 seconds, and huge smoke plume!!! any help?
NovakTwo 08-06-2009 07:24 AM
What went Poof----motor or speed control?
dgrobe2112 08-06-2009 07:54 AM
speedo..
racer1812 08-06-2009 12:54 PM
Sorry to hear that. I have 2 vortex motors and they run fine on my GTB's.
meon99 08-10-2009 01:07 PM
OMG:cry:
bennybtl 08-10-2009 01:16 PM
uh oh. sounds like a bad gtb or a solder issue. That motor should work fine with the gtb. :cry:
