Futuba Brushless servos BLS 452 >
Old 05-16-2009, 11:01 AM
lethalleigh29's Avatar
Default Futuba Brushless servos BLS 452
i have noticed that these servos state Ni-cd use only is there a reson for that or are they safe for use with ni-mh and lipos.
lethalleigh29 is offline
Old 05-16-2009, 11:04 AM
Armstrong's Avatar
Trader Rating: 18 (100%+)
They should work with Lipos without problem. Just make sure that the regulator you use can handle the high amp draw by the servos.
Using them with NiMh would sometimes let the voltage drop low enough to let the receiver do a reset.
Armstrong is offline
Old 05-16-2009, 11:16 AM
Cheers for the quick reply could you please explain the Nimh again i dont quite understand
Cheers
i mainly use NiMh and dont really want to go to lipos unless i really have to i have bad experiences on lipos including a wrecked motor due to regulator failure.
Old 05-16-2009, 11:23 AM
Armstrong's Avatar
NiCd's are more capable of sustaining their voltages during high amp drain situations i.e. the servos are under load. Under load situations, the voltage of the NiMh would drop momentarily and let the receiver turn itself off and then on again. The moment it turns on, the receiver has to check for an open channel again before reconnecting with the transmiiter.
You can still try it with NiMh though. Just make sure that your receiver can sustain the lower voltages. The Spektrums in particular are very sensitive to low voltages.
Hope this clear things up
Kevin
Old 05-16-2009, 11:41 AM
Kevin
cool thanks mate i am running the 4pk for the first time with these servos and i was just concerned over that little statement i will be running them in the steering of my RC8 so i will give a serious testing before i go out a crank a big race.
Old 05-17-2009, 01:12 PM
are the servos direct lipo compatible
Old 05-19-2009, 03:59 PM
is there anything else i need to know before running these servos.
Old 06-04-2009, 06:53 AM
can these servos take a lipo direct.
Old 06-04-2009, 07:22 AM
Kyosho_101's Avatar
only one way to find out and then it will answer the question for me so go ahead give it a try whats the worst thing that could happen
Kyosho_101 is offline
Old 06-04-2009, 07:23 AM
Smoke and fire.
Old 06-11-2009, 10:03 AM
B.A. Racer's Avatar
i just got the same servo..i run an rc8e and of course u use lipos...have any problems with it?
B.A. Racer is offline
Old 06-12-2009, 07:13 AM
yeah but doesnt the speedy regulate the voltage going to the reciever hence you would only be putting out 6 volts to to the servo.
Old 06-12-2009, 08:30 AM
99% sure an ESC outputs 6V, the servo would be fine on an electric set-up, not too sure on the LiPo part though.
howtowakeakar is offline
Old 06-12-2009, 09:06 AM
yeah thats what i thought im just gonna have to try it and find out what happens.
Old 06-12-2009, 07:05 PM
Wenbiao's Avatar
me too
Wenbiao is offline
