-   -   M8 won't turn off! (https://www.rctech.net/forum/radio-electronics/296565-m8-wont-turn-off.html)
Jam-ehz 05-12-2009 12:36 PM
M8 won't turn off!
Strange thing happened last week at the races.. The radio was switched off, I put my radio down (stood up), the table was knocked, tipping the radio. I stopped the radio from falling over (it wasn't even close to hitting the surface), and it just turned itself on! The display was on, lights were on, I could navigate the menu, all while the switch was off.
I have the Spektrum Pro module, and it will only activate when the switch if on. The receivers go into safe mode when the switch is off.
I now have to pull the pack out when I put it away.
Is there a common fix for this?
K_B 05-12-2009 01:07 PM
Doesn't the M8 have a "display" switch? This allows you to jack around with the settings without transmitting I think. But it should reset itself if you turn the radio on/off.
SachaSki 05-12-2009 01:08 PM
I don't know the M8, but on my 3pk there is a switch to turn the screen on which allows you to navigate in the menus and set the TX but it's not emitting..and the power switch is off...so maybe take a look at the user's manual...
Hide 05-12-2009 01:20 PM
You also have to turn the backlight off, as well as the main off switch. The backlight stays on, but the radio is off if you understand me.
JeromeK99 05-12-2009 02:51 PM
The M8 does have a "display" switch that stays on until you switch it back off. Check the display switch.. i bet that's it.
Jerome :tire::tire:
Hyde 05-12-2009 04:49 PM
Jerome :tire::tire:
:tire:!
+1
Jam-ehz 05-12-2009 08:32 PM
Hah! That was it.. geez I feel like an idiot.. :D
My hand must have hit that switch when I stopped it from tipping..
Thanks everyone for the advice!
