Strange battery behavior!
Hey guys~
One of my 4s 5000mAh packs is acting funny. It charges just fine and reads perfect when tested. The problem is that the battery has NO punch when I run. I am thoroughly confused for my Hyperion charger does not alert me of any issues either. Any help would be greatly appreciated, thanks! |
You may have a internal connection prob - connection has come unsoldered, but the wire is sitting on the cells solder tab - lets you ck voltage and charge and etc, but when its stressed - ie load put on it, the connection is iffy enough that it fails to deliver.
Sounds like you may want to take pac apart and see if connections are sound. That'd be the 1st thing I'd look at given the behavoir. |
Originally Posted by Duster_360
(Post 5796973)
| All times are GMT -7. It is currently 12:03 PM. |
