problem w. vislero a6 charger
Hello,
on ebay I did buy a used vislero a6 charger, in like-new condition. Problem is - it does not work. either charging a nimh or a 5s lipo, I always get the following message after a while : current err
the small manual doesn't help, has anyone an Idea? is there an other manual available? when connecting with a lipo, sometimes it has a problem to detect the right battery-type. when starting the vislero, it says 13,5v incoming voltage, that should be ok. the power supply is pretty strong and worked well the past years.
as my tunigy charger does not balance at all (cr..py thing), I got that vislero. the techdata semms quite ok. but here in germany it's not known at all...
thanks
florian
thanks
florian
I have tried that, but with no effect...
