Needed: Tutorial On Shortening Servo Wires
Ok, so how do i reduce the length of servo wires without causing damage?
Originally Posted by Airflow
(Post 5776101)
Or you can cut the wire to the length you want and redo the connector -
http://www3.towerhobbies.com/cgi-bin...?&I=LXTSH5&P=M You can trim the tab off. |
Originally Posted by AndyMoore
(Post 5777619)
Open up the servo and solder a shorter lead to the board. You definitely want to have a small tip and a hot iron though.
Thanks, have to practice first on a broken servo before I do
it on my digital servo. |
try this.. take a screw driver as long as the wire and start at the end closest to the servo. wrap the wire tighly around the screw driver giving the wire a sprial shape when removing it do not untwist just plug right in. this will shorten the wire length and make wires 10x neater
Apply a LITTLE heat from a heat gun to the wires before you take them off the screwdriver will help "set" the coil.
Bob Oaks |
Nifty tip, bob o !!
| All times are GMT -7. It is currently 09:18 PM. |
