M11 Question O.o
sup everyone! can I put my old skool M8 FM RFmodule in my M11? the M11 has 2.4GHz module in it but just wondering if I could switch from MHz to GHz. . .
No harm in trying. I can't remember off-hand, but I know that one of the radios has more module pins than the other, so it may not physically fit.
You should be able to run the same module in both the M8 or M11 without any problem.
Originally Posted by K_B
(Post 5756719)
Originally Posted by Trips
(Post 5756857)
thanks trips for the good info.. are you 100% sure? or?... |
The worst that could happen is that it won't work. It's not gonna spontaneously combust or fry anything or whatever.
(Post 5757497)
The m8 modules will work ...just make sure it has 8 pin holes......if im correct early modules had 6......but they will work in the m11
Bingo you are right on that early versions had 6 pins compared to 8 for m11.If your module only has 6 let me know I might have extra one laying around somewhere
I have a M11 that came with the dss. Then I picked up a 75mhz and 27 Mhz modals from novak. when I received the modals I quickly fund out the only have 6 pin holes when my M11 has 8 pins!! Broke out the Dremal and added two more holes. Now they work fine. so you shouldn't have a Problem
Jake |
My M8RF Module has 8pins! So for sure it will work. I haven't try yet tho lol
Thanks for all the info people. Thanks again! |
| All times are GMT -7. It is currently 01:46 PM. |
