Telemetry kits (handheld)
Has anyone used one of the spektrum handheld telem kit witha sr3300t reciever and sensors?, does it work with the reciever or do you need the telem box attatched also?
Originally Posted by micknshery
(Post 5721780)
awesome... thanks, I just recieved the elec telm handheld kit, and am having problems getting her up and running on my first car which is running the on board unit and a sr3100 rx to a dx3r, any advice or ideas appreciated!
When on board telem box plugged in to reciever, I managed I thought to get it all to bind lights reacted accordingly. BUT...handheld unit not picking up any signal. Also whenever you turn off the car and then back on again it sends the rx back into bind mode? I have followed the written instructions, I think! lol tried allot of different stuff but to no avail, my end result is the same, no signal being sent to the handheld or it doesn't appear to be and whenever you turn car off and back on again because on board is plugged into bind battery port on rx it sends the rx into bind mode..... Please Help! lol |
Bugger, just read the prior post on this.....so the dsm2 reciever is not compatible with telem on board unit....can I still run 5.5ms response for my steering through the sr3300t rx with no prob's?
(Post 5726320)
so the sr3100rx is compatible?, I removed the bind plug as per the manual, and did the bind on the handheld, but with the on board unit plugged in to the bind port of the rx sends the rx back into bind mode everytime switched on...
Plugged in the sr3300t worked first go, and after redaing a prior post you state the sr3000 sr3001 and the sr3300t are the only compat rx's with on board telem...would really like to be running the sr3100 dsm2 but doesn't seem to wanna work? |
(Post 5726650)
Plugged in the sr3300t worked first go, and after redaing a prior post you state the sr3000 sr3001 and the sr3300t are the only compat rx's with on board telem...would really like to be running the sr3100 dsm2 but doesn't seem to wanna work? The ONLY receivers compatible with telemetry are: SR3000 SR3001 SR3300T If you're trying to use the SR3100, that's the problem right there. Also you don't use the SPM1325 with the SR3300T, it's built into it. |
Yep, got the gear working last night with the sr3300t, understood you don't need the on board unit with the 3300rx...Thanks for your replies, appreciate it. That kinda sucks though.lol
Thanks again Mick |
| All times are GMT -7. It is currently 09:23 AM. |
