-   -   Balancing Question (https://www.rctech.net/forum/radio-electronics/289083-balancing-question.html)
JonNBR 04-10-2009 10:11 PM
Balancing Question
Whats up guys. I just got a Common Sense Balance Pro lipo balancer for my Thunder Power Pro Race 2c battery. In the balancer`s instructions, at one point it says, that if the cells are at more than 3.2v, it should be charged at a rate of up to 2C. What is a rate of 2C? My chargers rates, are rated in amps. .01amp-5amps. Can anyone break down what this is for me?? Thanks alot
gulio 04-11-2009 04:13 AM
"C" means capacity in mah , so 2C is double of the capacity in current.
Duster_360 04-11-2009 09:51 AM
C is current -its calculated from capacity divided by 1000 - if batt is 5000mah, 1C is 5000/1000 - 5amp. 2C would be 2 x 5amps = 10amps. If your charger can only go to 5amps, you'd just charge this 5000mah at 5amps. It would just take longer to charge.
JonNBR 04-11-2009 08:05 PM
Awesome. Appreciate it alot fellas
Smacka 04-12-2009 04:07 AM
ok... similarish qn.
iv just recently gone from 1:18th to 1:10th and iv noticed that compared to micros/minis, the bigger electronics are a real kick in the pills for your wallet. im used to forking out $20 on ebay for an ok lipo but for 10ths its anything over 100. So... i was wondering. i have in the past bought 1500mah 20c 11.1v lipos for my 18ths and been happy with there performance and price. iv been thinking of wiring up 4 of these in series to make them 6000mah and 80c for my 10th. the dimensions of 4 packs together would fit perfectly. however i hav no experience wiring lipos in series and i know that precautions should be taken. should i charge the individual packs separately and then wire them in series on each charge? or somehow rewire the ballance wires and charge it like a single pack on 4c? cheers
Smacka is online now Report Post Edit/Delete Message
Smacka 04-12-2009 04:51 AM
just realised i wrote series in the above... i meant parallel
gulio 04-12-2009 09:57 AM
As long as the 4 packs contain the same number of cells you can parallel any number of packs together. Using 4 would indeed give you a 6000 mah 11.1 volt pack and can be treated as such when charging and using. It can and should be left together if used together.
All the + will be hooked together and all the - will be together. Same for the balance taps if you want them to stay equally balanced between packs as well. I can see it getting very messy with 4 packs and having a lot of cost/labor/complexity compared to one pack.
Duster_360 04-12-2009 11:36 AM
If you connect the cells to the balance tap in parallel, the balancer will not see the cells individually. That defeats the purpose of balancing. The heli how-tos on charging two heli lipos at the same time all wire the balance wires in series so the balancer can see and balance each cell. This is a how-to charge and run a pr of 3S1Ps as a 6S2P lipo. Note what he says in the 1st paragraph.
http://www.rbgrn.net/content/46-how-...ks-single-6s1p
It will be complicated trying to get this right and you may never get there. There will be 12 cells involved and I've never seen a balancer that does more than 6cells. If you do any of the connections wrong, you risk all the batts and your charger. The other poss is to charge/balance them separately and then run together. Not the best, but an option.
Just buy a 10th or 8th sized cheap lipo and maintain it. Far less risk that something can go wrong.
gulio 04-12-2009 12:00 PM
Parallel cells are balanced automatically just because they are connected. Leaving them unparalleld will result in "packs" being equal , with potential un balanced cells within each pack. If left this way they can be balanced "on the side" so to speak with 1-4 balancers.
drperry 04-12-2009 01:13 PM
Balance and charge the packs separately, and just have the adapter to connect them all to the car.
But you can find an okay pack for $50 these days on E-Bay.
Also, look into Apogee packs, the one in my RC18MT has been awesome.
