-   -   Problem with sanwa M11!! (https://www.rctech.net/forum/radio-electronics/287419-problem-sanwa-m11.html)
Andy63 04-04-2009 08:54 AM
Hello! I am installing my M11 and run 1:5 GT and user when the 3 servos, one for gas / brake, steering and one for the front brake. therefore, 3 channels.
On Sanwan says that there should be user 4 channels setup for 3 channel is included there. I can only choose between 2 channel and 4 channel.
Now the problem. Everything works perfect with 2-channel setup, except third channel with the front brake on. This is normal. But then so do I transmitter 4 channel so does absolout nothing work, steering and gas / brake does not work at all at either. I can not see why. Tried most of what is in the book but I am not very sensible of it.
I can not understand why servos do not move at all as soon as i switch to 4 channel setting? I have tested most of what set ourselves 3 channel or 4 channel absolout but nothing happens. ago so I change back to 2 channel and then everything works again.
If someone knows the problem, write directly, because I want to get it ready so you can drive:)
K_B 04-04-2009 11:55 AM
Are you using FM or 2.4Ghz? I believe you have to re-bind the transmitter/receiver when switching between 2-channel and 4-channel mode when using 2.4Ghz.
Andy63 04-04-2009 12:12 PM
Yes, iam using 2,4ghz, forgot to mention! So i should rebind it when i switch to 4 channel? I dont have to turn off the transmitter or receiver to use 2 channel again and it works fine.
:weird:
Andy63 04-06-2009 12:44 AM
thanks, my problem is solved, i had to rebind it to get it work. :)
trf_414_m2 12-11-2011 03:23 PM
Hi guys.
Know this is and old thread but didnīt find a clue about my problem on recent posts.
A friend got a M11 and needs to "rebind" it as soon as he changes from 2 to 4 channels and backwards too.
Iīve found a non Sanwa/Airtronics 2.4GHz 4ch module and receiver that perfectly works with my M8 (3 channels)
Is the activation of the M11 4th channel setup linked (and only) to the use of original modules?
Do you think I can install my "custom" module and get a 4 channel radio?
Sorry, I wont answer questions about "my" module....
:weird::weird::weird::weird::weird:
All right, itīs a Team Associated 2.4GHz module plus 4 channel receiver...
Direct fit on M8 as it should on M11...
:lol::lol::lol::lol::lol::lol:
Help with the M11 4th channel binding, please.....
