-   -   any ESC's that are fully programable w/o a computer? (https://www.rctech.net/forum/radio-electronics/287204-any-escs-fully-programable-w-o-computer.html)
y2kgtp 04-03-2009 08:35 AM
Just curious...
any 1/10th ESC's that you can adjust at the track w/o a laptop to tune it? I was thinking of picking up a cheap Eee 2G used to toss in my toolbox, but seems overkill to just play with settings..... :lol:
Cpt.America 04-03-2009 10:19 AM
I think just about all of them can. The LRPs, the Tekin RS'.... they are programable right on the front of the ESC. I don't know if you have the ability to FINE tune as much... but I know you can set most of the settings using the interface on the front of the ESC itself.
whitrzac 04-03-2009 10:56 AM
the tekin has most of the features available without a PC, but the motor timing, boost, and sensored/dual mode, are only available by using the hotwire.
rcterp 04-03-2009 11:05 AM
The Losi Xcelorin is pretty good. There's a programming card that you plug into the receiver wire that lets you adjust everything using jumpers (cut-off voltage, braking, drag brake, motor timing, and throttle limit) except the acceleration and braking curves.
Worth a look.
abailey21 04-03-2009 11:25 AM
Speed Passion
y2kgtp 04-03-2009 12:47 PM
Originally Posted by abailey21 (Post 5636239)
Speed Passion
I saw that option for the 1/8th buggies, but is it the same for the 1/10th?
Drifting101 04-03-2009 07:10 PM
The SP ESCs have a very nice setting card!
Dave H 04-03-2009 07:59 PM
Yep, and it's standard, not an option. It's a great setup, makes everything easy to set, fits in the toolbox no problem. Much better than blinkity lights or dragging a laptop around, especially at a dusty off road track.
Speed control itself is cool too, does just about everything, sensored, sensorless, or hybrid of the 2. Adjustable timing, adjustable punch, yada yada.
Dave Barber 04-06-2009 11:47 AM
Ditto to Dave H, I really like mine and its in a XXXT.
Check it out at Banzai.com
NovakTwo 04-06-2009 01:16 PM
Novak's SLYDR and soon-to-be-shipped Havoc 3S have full, on-board programming needing no external computer or card:
Nine adjustable parameters:
Minimum Brake (10 settings from 3-50%),
Drag Brake (10 settings from 3-50%),
Dead Band (5 settings from 2-6%),
Minimum Drive (5 settings from 2-12%),
Throttle Curve (Linear, Expo-1 and Expo-2),
Brake Frequency (7 settings from 1-8 kHz),
Reverse,
Motor Rotation
Li-Po Cut-Off
y2kgtp 04-06-2009 02:03 PM
Well, I just picked up a used Eee for 125$ shipped, so will install XP on that, and then my Losi software. And when I get my 13.5T combo, whatever brand that might be the software for it too.....
I bet I might make a few friends with one of these at the track...:lol:
