M11 Question
I have an M11, love the radio but have a question about it.. I used to run JR XS3, I run oval, and liked the button right by your left thumb on the controller so i could get full steering by holding that button. Does the M11 have a feature like that?
Originally Posted by RoosterXp
(Post 5606174)
I think he's referring to the button that would momentarily override the dual rate setting and give full steering throws when held. The M11 doesn't have that feature, but it should be possible to duplicate it using a program miz.
Originally Posted by Trips
(Post 5607661)
that is exactly what Im talking about. What is a program miz? thanks guys! |
you can program the m11 to have full steering when you hit the button. It wont be momentary but it will be a on or off thing. you set a c-mix so you will clone th steering servo to be like another servo.
c-mix 1 master=st1 slave=st L=max offset=0 R=max c-mix=inh set the c-mix 1 to what ever switch you like but it you will have to click it to turn it on or off. |
| All times are GMT -7. It is currently 02:00 PM. |
