-   -   Servo messed up (https://www.rctech.net/forum/radio-electronics/284915-servo-messed-up.html)
yummyguts 03-25-2009 12:52 AM
Servo messed up
Hey,
I had a crash with my tamiya mighty ballista and now
the throttle servo is all messed up. For example it if pull on the throttle it
will stay at the amount of throttle you pulled and then you have to pull on the brakes to get to idle . Now it just keeps going to full throtle and pulling on the brakes doesnt do much. Any ideas
thanks yummyguts
Toh WL 03-25-2009 01:51 AM
Originally Posted by yummyguts (Post 5594847)
Hey,
thanks yummyguts
First of all check you servo if any gears are damaged. Try swapping the ESC and see how's the servo movement.
yummyguts 03-25-2009 04:14 AM
thanks ill give that a try'
