hows this charger?
i have the onyx 230,, i just need a charger that will do 4s lipos, money is very tight right now thats why i like this one.i know i need a power source too.
http://www.hobbycity.com/hobbycity/s...rger_1-5_Cells The IMAX 5B computerized balance charger packs a big punch. With up to 5 cell balance charging, delta peak sensitivity, capacity limit, input power monitor and smart and highly configurable charging. This charger will be all you could ever need. Features; Microprocessor controlled Cell checking and status Delta-peak sensitivity Individual cell balancing Li-ion, LiPo capable Ni-Cd and NiMH capable Large range of charge currents Time limit function Input voltage monitoring. (Protects car batteries at the field) Spec. Input Voltage: 10~18v Circuit power: Max Charge: 50W Charge Current Range: .1~5.0A Ni-MH/NiCd cells: 1~14 Li-ion/Poly cells: 1~5 Pb battery voltage: 6,12v Weight: 280g Dimensions: 130x80x23mm This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, Loong Max and any pack with a JST adapter. |
| All times are GMT -7. It is currently 10:43 AM. |
