polyquest balancer???
guys i just bought one off ebay..http://cgi.ebay.com/PolyQuest-Lipo-B...ayphotohosting my charger has a dean comeing off it... how does this hook up to the balancer??? or do i have that wrong.... can someone fill me in how balancers hook up
so guys i hook up the lipo to the balancer let it balance then hook my charger up the the lipo wile the balancer is pluged in then charge.... is that right?
Should be able to balance while its charging, all hooked up together. If you balance while its off the charger, any balancer will just discharge the highest voltage cells down to equal the lowest voltage cell. This may cost you capacity depending on how much diff in voltage there is.
Usually this type balancer can do both, act as a standalone balancer (sometimes called passive mode) and an "active" balancer balancing cells while batt is charging. The active mode will give you a batt charged to its highest capacity. Should be just a matter of reading instructions and making the connections. |
cool man.. i just bought a used maxamps 6000 20c 7.4.. off the bay.. kid says it has less thank 100 cycles on it... his feedback is 200 all pos.... i just hope its a good pack... thats why i just bought that balancer... 65 bucks for the lipo.... ill be buying some new ones soon..
From what I've read about MA packs - you'll need the balancer. Their cells seem to become unbalanced when they're used. Good luck with it, hope its what you expect!
Originally Posted by Duster_360
(Post 5495877)
guys how do i hook up this balancer up to my charger??? they gave me a plud to go from the bal to the charger but has no end on it? do i just put a dean on it and plug it into my charger??? let me no
| All times are GMT -7. It is currently 02:19 PM. |
