DX3R DSM2 vs. DX3S DSM >
Old 02-28-2009, 02:09 PM
MoparRules's Avatar
Default DX3R DSM2 vs. DX3S DSM
Hi. I was just wondering what is the difference between these 2 radios. The DX3S seems better because of the telemetry but why is the DX3R $70 more?
Also, what is the difference between DSM and DSM2?
Thanks in advance.
MoparRules is offline
Old 02-28-2009, 02:27 PM
iPearl's Avatar
Trader Rating: 96 (100%+)
DX3R More options, Larger memory bank, Telemetry and DSM2 Is faster
DX3S Less options but already alot for a new person to get overwhelemed with. DSM1 is slower but as a Casual Driver you wont feel a damn difference.
I barely felt any difference form Spektrum to Spektrum Pro. Maybe a little smoother but i am not sure if its the 2.4 or the servo. But i think the S has Telemetry also ? As a racer i bet you can feel the difference but as a casual driver or basher i doubt it. Heck i see some of the guys going to IFMAR with still FMs and reg DSM and 2.4 Kos
AM to FM to 2.4 will feel difference though.
iPearl is offline
Old 02-28-2009, 02:31 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
30 model memory vs. 10, frame rate in the 3s is 11ms only, the 3r gives options 5.5, 11, 16.5. Must run 5.5ms for digital servos with the 3r so I don't know if you can use digital servos with the 3s cause it doesn't have the 5.5 frame rate. I'm not sure if all the other options are the same between the 2, expo, mixing, etc. I have a 3R, personally I don't need or want all the telemetry crap but that's just me. DSM vs. DSM2,,,not sure hopefuly someone will fill us in on that. I do know that a dsm2 receiver will not work with dsm radio but a dsm2 radio will work with dsm2 and older dsm recievers. All being Spektrum of course.
racer1812 is offline
Old 02-28-2009, 02:40 PM
MoparRules's Avatar
well i dont plan on ever owning 30 cars. i dont think theres 30 cars/ truck that i like!
as for the difference in speeds, i wouldnt care. as long as its better than my stock HPI 27mhz radio, im fine.
i like the telemetry because i thin it would be cool to know about your car while its moving. think about it. not having to stop every minute to check the temp of an engine while you are breaking it in!
plus im glad i can get a great radio for under $300!
thanks all.
Old 02-28-2009, 02:54 PM
Super Moderator
racer1812's Avatar
A string tied to your car gives better control than a stock 27mhz radio. You'll love a 3S then. I would still verify temps periodically with a quality temp gun though and compare the numbers so you know where your at. Especailly when you first set it up.
Not bashing on the telemetry stuff I just don't have any use for it, but it is kind of neat.
Old 02-28-2009, 07:25 PM
Trader Rating: 28 (100%+)
Racer 1812:
I believe you are a bit confused.
You do not have to run the 5.5ms frame rate when using digital servos. However you cannot run the 5.5ms frame rate unless you are using digital servos.
The 3S comes with the telemetry stuff built into the radio so you don't need to get the seperate unit needed if you use the 3R. The 3S also comes with the 3300T telemetry receiver.
The advantage(s) of the 3R is the faster frame rate, the model memory and the DSM2 technology. You can use telemetry with the 3R but it is a totally seperate unit.
Scott Fisher is offline
Old 02-28-2009, 07:48 PM
vios8820's Avatar
Trader Rating: 65 (100%+)
JUST GET DX3R !!!!
i already have bad memories with DX3s..
when 1st time i recivied and blind it failsafe not working..
cheap built quality ~~
vios8820 is offline
Old 03-01-2009, 01:59 AM
The telemetry stuff is handy, really nice to monitor temps and with the built-in alarms.
Check if you can get a LHS to pull the second receiver and save abit of cash if your only intending to use it on one car.
I personally cant notice any better driving between the guys at the track I goto that have DSM versus DSM2.
jonoz is offline
Old 03-01-2009, 04:37 AM
Foxxrocket's Avatar
I tried the two, and DX3R just felt better in my hand. Smoother, and an easier trigger pull than the DX3S.
That's what sold me...
Foxxrocket is offline
Old 03-01-2009, 05:34 AM
Pablo Diablo's Avatar
I recently when through the same delema and ended up with the DX3R. I've read quite a few bad comments regarding the build quality of the "S". Seems the toggle wheel is prone to breaking. For some reason they use a different toggle wheel on two very similar radios! And as said before the "R" give you the option of up tp 5.5ms response when digital servo's are used.
So far no complaints from me with the DX3R.
Pablo Diablo is offline
Old 03-01-2009, 06:04 AM
MoparRules's Avatar
what sucks is i dont wanna spend $300+ on a radio. ill go to hobbytown later and see which one seems better to me.
thanks guys.
Old 06-05-2011, 08:25 PM
Trader Rating: 130 (100%+)
I have a DX3r. I got it for $150 lightly used. It works great. I don't know why people say they don't want to spend $300. You really don't have to.
8ight-t_sbs is offline
Old 06-05-2011, 08:41 PM
MoparRules's Avatar
.... holy bumped thread batman
Old 06-05-2011, 11:36 PM
td-civ's Avatar
Trader Rating: 18 (95%+)
if your only looking to race sometime and mostly bash with it the dx3s if more then fine the dx3r is more of a racer radio
faster frame rate
abs
servo speed
exponential
mixing
idle up for warming up nitro motor
tractin control
trim step
the dx3s dose not have this so if you need any of this that is listed then get a dx3r if you dont get the dx3s you can still use digital servos on it and it will work fine
i own a dx3r pro, dx3r and 3 dx3s and have raced with my dx3s many times and the car ran the same as if i was running my dx3r pro
but dsm2 is better and faster so if you do get a dx3s you will want the newer one as it is dsm1 and dsm2
td-civ is offline
Old 06-06-2011, 09:39 PM
rollmeover's Avatar
I recently purchased a dx3s with telemetry receiver and have had issues with glitching from the start. I am talking about more than about 50 feet away or so and it would do a repeatable throttle glitch after braking. I tried everything to fix it, adjusted linkages, swapped servos, re routed antenna, you name it.
Put an older spectrum receiver in it, problem solved. I called HH and they are sending me a new receiver so we will see if this solves the issue. I have nothing but great things to say about their customer service but I certainly hope this takes care of the problem. Let's face it, I knowingly paid extra for the telemetry and I want it to work.
A++ on Horizons customer support, product quality is yet to be decided on the dx3s for this customer.....
rollmeover is offline
