Sphere Brushed Brushless Forward/Reverse/Brake
I recently purchased a Sphere Brushed Brushless esc with Forward / Reverse / Brake and I don't seem to be able to get it to work with forward / brake / reverse as the brochure says it has. Am I doing something wrong or does this speedy only work forward / reverse or forward / brake? If this is so, how are you supposed to be able to slow down when you have it in the forward / reverse mode?
I am using a Futaba T2PHK and a Futaba 3PM 2.4gHz radio and neither of them seem to work the reverse function. I look forward to any advice. Nick |
The Sphere doesn't have fwd/brk/rvs as an option, you get either brake or reverse profiles.
For racing you disable reverse, so I haven't used that mode, but there should be a little brake delay in fwd/reverse mode, light trigger pressure will slow you down before it slams into reverse. |
You'd think with all their German technology they'd be able to achieve this simple function that even a basic Tamiya esc can do!
| All times are GMT -7. It is currently 11:54 PM. |
