? on Novak GTB
I thinking of putting the GTB/SS 10.5 in my new B4. I looked on Novak's site and didn't see if the GTB esc has Lipo cutoff protection. Can someone with the GTB answer weither the GTB as LiPo cutoff?
gtb esc
Yes it does have a lipo cut-off I'm running a gtb w/ a 3.5r motor
What happens when you connect a LIPO batt and forget to enable the lipo cutoff?
Originally Posted by Danteazy
(Post 5420638)
Originally Posted by infamouse_1
(Post 5420437)
Provided it's the latest version, it has a LiPo cut-off mode. If it is not enabled, you could ruin your battery.
Jerome :tire::tire: |
also if your confused if the cut off is on or off when you turn your esc on the red light will blink 3 times and that shows its enabled
Originally Posted by not home
(Post 5420646)
well it looses all of its power, wont take a charge, and may puff too i think. you dont want to do that.
(Post 5420646)
Originally Posted by M-Technic
(Post 5422565)
ONLY if you run the battery too low. Simply running the car with no lipo cutoff is fine as long as you have a mind to not run the car too long.
I run an Orion 3200 with my stock 2wd buggy with a Novak GTX... but I never run more than what I do in a race anyway.. even during practice.... Jerome :tire::tire: |
I plan on running a timer as well. I just want to have something to fall back on, because I still forget to go in and reset the timer.
(Post 5420638)
(Post 5420646)
Originally Posted by racer1812
(Post 5426325)
I'm sure what you meant was what happens if you run a lipo without a cutoff. Nothing happens when you "connect" a lipo without a cut-off but if your run the lipo down to far you may get poof, swell, smoke, fire, maybe not in that order though..lol:weird:
Most of the local racers at our track don't run the Lipo cutoff because momentary voltage drops from hard acceleration with powerful motors can cause the lipo cutoff to kick in even when there is plenty of juice left in the battery, leaving you dead and stranded in the middle of a race. |
| All times are GMT -7. It is currently 06:33 PM. |
