-   -   Protek Lipo problems (https://www.rctech.net/forum/radio-electronics/273659-protek-lipo-problems.html)
sleek the elite 02-07-2009 01:18 AM
I am having problems charging a new protek 2200maH 14.8V Lipo on my swallow 2 charger. The charger charges all my other lipos but says "output circuit error" when I try and charge this pack. On the multimeter, the pack reads 15.8V, which I would think is about right. I pu i on the balancer, and that seems to recognise it ok. I don't have another charger to try it on.
Anyone have any ideas what is going on ?
Thanks.
Duster_360 02-07-2009 02:38 PM
I don't have this charger, but the error message may be related to your charging leads. I know my Hyperion charger is sensitive to what gage and length wire is used to connect batt to charger. What are you using for charge leads?
sleek the elite 02-07-2009 04:46 PM
I'm using banana plugs out of the charger connected by a short wire to an ultra plug. Tried charging it throught the hyperion balancer also, that doesnt work either. Might try some longer leads. Thanks
sleek the elite 02-07-2009 05:07 PM
Actually I think the problem may be on the charging end after all. Just thinking about it, the charger would not charge a 14.4 V NiMH pack either, so it seems to have problems with higher voltage packs.
