Futaba servo question
i have a Futaba S9551 servo that says it is only to be used with Ni-Cd batteries.... Can this be used with Lipo? Do i need anything to do this?
Originally Posted by blacksheep
(Post 5359124)
back of the box, right below where it gives the specs.... there is highlighted text that reads "Ni-Cd use only"
That is there because they don't recommend using the little 4 AA style battery when using digital servos. You can use 5 cell NiCad, and NiMH. If you want to use a 2s lipo you will probably want to use a voltage regulator as well. I would not advise using a 1 cell lipo.
not sure i understand.... I run my JR Z9100S with out voltage regulator.... If i do need one do you mean something like this
http://www.spektrumrc.com/Products/D...ProdID=SPM1600 |
(Post 5360066)
http://www.spektrumrc.com/Products/D...ProdID=SPM1600 Nitro, 2s receiver batt, suggest an add on BEC/voltage regulator like these: (or run/risk higher voltage) http://dimensionengineering.com/SportBEC.htm http://teamnovak.com/products/BEC/index.html The item you posted is to reduce short term voltage drops when you punch it, to help the radio. Mostly 4 cell 12th scale. |
Thanks....
| All times are GMT -7. It is currently 09:35 PM. |
