-   -   Futaba 3PK module (https://www.rctech.net/forum/radio-electronics/270905-futaba-3pk-module.html)
TXRC8racer 01-27-2009 06:59 AM
Futaba 3PK Question
I want to upgrade my 3PK system to the new Futaba Fasst system or the Spektrum system, which is a better 2.4Ghz system for the 3PK?
TXRC8racer 01-27-2009 12:12 PM
Here is a little more detail of what i need
Choices are:
Spektrum DSM 3CH Module Surface System retails for around 160.00
Spektrum DSM Module System: FUT 3PK, HRS Only retails for around 200.00
Overview
Futaba 3PK owners interested in the fastest possible processing speed are sure to be blown away by Spektrum’s latest engineering breakthrough.
A new, dedicated module and receiver have been developed specifically for use with the Futaba 3PK when HRS modulation is selected. The Spektrum latency has been reduced to just 2ms.
This system is designed for use with digital servos only. The module and receiver are designated “Futaba HRS Version” and are for use with the HRS system only.
Spektrum DSM 3-CH Pro Series Surface Module/Rx: FUT/HRC for 100.00$
And i need to get some info on the Futaba Systems
Any input guys.
TXRC8racer 01-29-2009 12:35 PM
I know someone has some input.
I have read that the Futaba Fasst system is not that reliable but has there been any problems with the spektrum systems.
Or do i even need to upgrade im running Hitec 7955TG dig servo and a Hitec5965 servo for my throttle/brake and im in HRS mode and running a Futaba
R203HF reciever along with a OFNA 1600mah reciever pack battery. I have never had a problem on the track at all but i do have a little twitching noise comming from the servo's is the common or not thanks for your help.
