4pk and the Futaba R603FS receiver??? >
Old 01-25-2009, 07:58 PM
HulkNT1's Avatar
Default 4pk and the Futaba R603FS receiver???
I was at the park today and they had a Car Show and power 96 was there. I was kinda of close to the action that was going on in the park and when I try to run my RC with my 4pk and the R603FS the car went out of control. I bind the receiver with the radio and place C1 on the radio but I have also Bind the 4pk receiver with other car I have and I switch back and forth depending of what car I am using..
Now back to the park my car when out of control what can that be?? Can it be that power 96 was there and transmitting and my radio got interference???
When I was using the receiver R603FS the signal was going and coming.
Whats the correct process of switch from car to car with the old receiver and the new receiver??
Thanks for you help
Felix
HulkNT1 is offline
Old 01-26-2009, 05:02 AM
jamminnay's Avatar
it can be something from the radio station freq.. i have heard of someting similair to that in the past..
jamminnay is offline
Old 01-26-2009, 09:40 PM
RCBLUE's Avatar
Thanks for you help
Felix
I always switch my model then turn my 4pk off then back on, cause when going from c1 to c2 can cause transmission issues. Or at least that is what has happpened to me.
RCBLUE is offline
Old 01-27-2009, 10:41 AM
Stein Tumert's Avatar
Thanks for you help
Felix
What is the serial number for the transmitter (see inside battery compartment)?
Stein Tumert is offline
Old 01-27-2009, 03:44 PM
HulkNT1's Avatar
Why are some Transmitter bad I will look for the number..
HulkNT1 is offline
Old 01-27-2009, 05:08 PM
Regional Moderator
Darkseid's Avatar
Originally Posted by RCBLUE View Post
I always switch my model then turn my 4pk off then back on...
This is actually what the instruction manual calls for. Anytime the radio is switched from a model using C2, to a model using C1(or vice versa) the radio must be turned off and then back on.
Darkseid is offline
Old 01-28-2009, 01:26 PM
Yes. There were problems with the first batch. Futaba replaced my transmitter and 3 receivers (604)...
