Servo Question...
Ok, Im getting a Futaba 3PM FASST... what servo is good for this
system? Should I be getting a digital servo? Will the S3003 work just fine with this system? Im not after the highend stuff, I just want a servo that is compatible with the 3PM but not that expensive. Thanks |
I am pretty sure that the standard S3003 servo should work fine. If you still want to get an upgrades servo check out this servo for high speed:
http://www3.towerhobbies.com/cgi-bin...&I=LXUZ87&P=ML Or this one for High Torque: http://www3.towerhobbies.com/cgi-bin...&I=LXUZ89&P=ML They are both great servos and are relatively inexpensive. The ones below are just the digital versions of the ones above. The high speed one: http://www3.towerhobbies.com/cgi-bin...?&I=LXUZ76&P=M The High Torque one: http://www3.towerhobbies.com/cgi-bin...?&I=LXUZ80&P=M I would personally recommend getting the digital because they are of better quality and will perform better. Plus they are inexpensive for a digital servo so there is nothing to lose, especially since it is made by Hitec. Which ever one you chose you will not be disappointed with. Good luck with your new radio. |
| All times are GMT -7. It is currently 12:16 PM. |
