-   -   ESC problem, possible solutions? (https://www.rctech.net/forum/radio-electronics/267971-esc-problem-possible-solutions.html)
megasaxon 01-16-2009 05:01 AM
I have a novak super sport brushless esc coming to me. I was told that it only works if you give the car a push. I don't know if the person i'm getting it from had tried other motors or not. Any ideas? Possible programming issue?
Steve Weiss 01-16-2009 07:58 AM
You should definately check to make sure that all of the connections have been made properly:
Sensor harness is fully seated into the ESC... none of the sockets are comming out of the plastic housing, etc.
All three motor phase wires are properly soldered to the motor
Blue to A
Yellow to B
Orange to C
If it doesn't work like that, give another known-to-work motor a try.
At that point if it is still giving you the "push start" problem, I would say the ESC has a problem with one of the power phases.
I would check out our website to see the upgrade options we have available for the Super Sport ESC.
www.teamnovak.com
megasaxon 01-16-2009 08:44 AM
Thanks for the info Steve, we'll see what happens when it comes in. I guess i didn't expect an answer directly from novak on here lol.
Drifting101 01-17-2009 03:47 AM
I received a motor that did that! Still cant get it to work so if you fix it please post up how
whitrzac 01-17-2009 08:32 AM
I thought there was a flaw with the older SS escs that made them do that???:confused:
light 01-17-2009 12:35 PM
I had a GTB doing just this also the speed was off a fare amount. and it was
Don't waste to much time on it Send it in for repair or a upgrade
-=light=-
