-   -   What batt pack for my hyper 7 (https://www.rctech.net/forum/radio-electronics/266341-what-batt-pack-my-hyper-7-a.html)
SeR_Cyclops 01-09-2009 08:46 PM
Hey, i bought a batt pack at my LHS for my hyper 7 it was part number ofna 10202 and i tryed to put it in my 7 and it was the wrong one so tomorrow im going to take it back, since i already paid for it i would like to see if he had what i needed in stock. i think i need a flat pack. but i would like to hear from you all so i dont waste yet another trip down there. also ill just throw this in there i lost a screw where the motor mount screws to the frame from the bottom side the hobby shop and i have looked everywhere for a part number and i have not found one so if you all know that that would also help me. thanks for your help.
buds302 01-09-2009 09:17 PM
if it was a hump pack.. there shouldve been an extra piece that was included with your hyper7 new. it would go where the existing battery holder is and is made for the hump pack.
as for the bolts...im not quite sure which part you mean... so
http://www.nitrohouse.com/catalog/pr...oducts_id=9786
that is the bottom plate that the mount sits on. it is bolted to the chassis..
and then here is for the actual motor mount which bolts to the plate... but the bolts to adjust are accesable from the underside only..
http://www.nitrohouse.com/catalog/pr...oducts_id=9787
this is what you need to make a hump pack work..
http://www.nitrohouse.com/catalog/pr...oducts_id=9791
either one you use you will still need to zip tie the battery down.. i lost one once...
or buy this batery...
http://www.nitrohouse.com/catalog/pr...oducts_id=8731
PS nitrohouse has everything you would need for your buggy. i was able to find stuff from them i could never get from any LHS.. shipping was awesome too. and seeing as thier building is right next to OFNA... it means they will always have what you need
SeR_Cyclops 01-09-2009 09:27 PM
thanks for the engine screws the screws i need are in the bottom link but surley i can get them with out buying all that extra stuff. also i have that extra tray its just the plug is different on the hump pack i bought.. i belive that is the battery pack i need the 1700 flat pack.
EDIT: i think this is the screw set i need. http://www.nitrohouse.com/catalog/pr...3f1fcb0fd35e08
UltegraSTI 01-10-2009 05:32 AM
didnt that car come with the option for straight or hump? seem to recall that, been over 5yrs since i owned 1. just recall that for some reason.
R
SeR_Cyclops 01-10-2009 06:07 AM
R
yeah it does but the plug is different from the pack that the LHS sold me.
RacerScott 01-10-2009 06:14 AM
The hyper 7 should of came with a plasice peice to hold a flat style receiver pack, I used to use eletrical tape in two spots to secrure the pack, some people used zip tires, but that will eventually tear the shrink wrap. I know the car also comes with a square plastic battery hold down, but im not sure if that will fit a hump, I thought it was just for the 4 AA RTR setup.
buds302 01-10-2009 07:19 AM
again.. he knows about that.... thes talking about the plug that plugs into the reciever.
SeR_Cyclops 01-10-2009 06:57 PM
yeah its ok i ended up taking the plug off the AA batt pack and putting it on the OFNA 5 cell 6v pack.
