I'm constantly having to set the trim.
What the heck. I just set up my Ft RC18T and no matter what the steering is never centered.
One second Its turning to the left, so I set the trim so it goes straight, next thing I know its turning right. And now I cant turn the trim anymore. What could be causing this? What can I do to fix it? |
it cud be ure servo is dodgey i had that hapening my car i had a bad traxxas servo in it and it was goin all over the place
also ure wheels may not be level, try different wheels or checking ure alignment;) good luck:nod: |
The servo as well as the saver that comes with it are pretty much crap. I had the same situation with my 18R I had for awhile. I swapped out the servo for something better and it was way better. Get rid of the stock servo and get something better.
I use the stock servo in both my race cars.(18b and 18r)
If you dremel a small groove into the plastic spring on the servo saver. Cut a ring out of a stock blue suspension spring(if you have spare springs) Pop the ring over the plastic servo saver into the groove. Also a little toe out helps keep it streight to! |
| All times are GMT -7. It is currently 09:47 PM. |
