-   -   Sidewinder or Mamba Max (https://www.rctech.net/forum/radio-electronics/263830-sidewinder-mamba-max.html)
portyansky 12-31-2008 08:39 AM
What are your thoughts? Its about an $80 price difference. Its going in my T4. It seems as the Max has more adjustments, but with my radio I can do all those adjustments.
whitrzac 12-31-2008 08:58 AM
http://www3.towerhobbies.com/cgi-bin...?&I=LXUTA3&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXUTA0&P=7
$60 diffrence
the MM has the same adjustments as the sidwinder
MM can handle a higher KV/larger motor
MM runs cooler
MM has external solder tabs, the sidewinder does not.
MM doesn't need a castle link, sidewinder does($25-$30)
need any more resions not to get the sidewinder?
Duster_360 12-31-2008 10:10 AM
MM will handle a lot more amps, but I don't see why you'd need the extra. Sidewinder looks like a good choice.
8&stuff 12-31-2008 01:09 PM
wow..this is the thread i was wondering the same things about..nice
wyd 12-31-2008 08:34 PM
The Sidewinder is fine as long as you don't run over a 5700kv motor. In a truck you will never need more than that at any track you go to. Theibig difference I have found is the Sidewinder rewuires 10% more drag brake vs the MM. I run 30% on the Max and when I use my Sidewinder I use 40%.
THEYTOOKMYTHUMB 01-02-2009 01:40 PM
You can get the Sidewinder 5700 or 4600 for about $132 shipped on ebay. The Sidewinder is a beast! I have both, but the Sidewinder would be my first choice when the price difference is taken into consideration. When you run it in any 2wd 1/10th scale vehicle it will be more power than you'll ever need. :nod:
UltegraSTI 01-02-2009 07:17 PM
i do miss my maxx already, but this sidewinder is a very good piece and a better pricepoint for most. depends on application. honestly if u race, i'd get the SW, if u bash or play drag hero on ur block w/ur friends, go MM.
R
rearviewmirror 01-02-2009 08:26 PM
I agree. the SW w/ a 5700kV is a monster, and a cheap source of power at that. I'm running this setup in an RC10T4, this is about 5x more power than this truck really needs.
clamber 01-02-2009 08:28 PM
Get teh sidewinder!
