-   -   RADIO FOR DUMMIES???? (https://www.rctech.net/forum/radio-electronics/263252-radio-dummies.html)
ghj1997 12-29-2008 02:35 PM
I got my first "real radio" MX3FHSS. I am confused on what all the settings actually do. Could someone give me a basic answer to each of these settings:
Dual rate
epa
arc
sub trim
Would really appreciate it.
CREWMAN 12-29-2008 03:31 PM
Not sure about arc
EPA= End point adjustment. This adjusts the amount of range (left Right) you give your servo
Sub Trim= Pretty much the same as trim on your other old radios. It just adjust the center point of the servo.
Dual rate i believe adjusts the throw? maybe someone else can help.
Personally once you set these to where you like them, I never touch them. The one i play with the most is the sub trim and and the epa for the different track configurations
