What is a good lipo/nimh charger?
What is a good lipo/nimh charger under $100? Was looking at the onyx 230 but heard it wasn't good for racing and thats what i want to have it for.
http://www.allerc.com/product_info.p...oducts_id=3630
http://www.rcaccessory.com/index.asp...ROD&ProdID=132
These are both DC chargers. The bantam unit will need a balancer, the hyperion has one built in.
Any with AC/Dc?
Only one I can find and its currently out of stock -
http://www.cheapbatterypacks.com/?si...LIPO&pgid=chrg
You might email CBP and see how long its going to be.
There are several chargers available starting at $140. Or, you could get an Accucell-6 by Turnigy and but one of their power supplies and pay for shipping and still be under your $100 limit. I've got one and its an awesome charger for the price. Some of their PS are shown on the same page.
http://www.hobbycity.com/hobbycity/s...lancer/Charger
aka how many cell are the avg Pro used Lipo cells ???
Does the accucell Balance Lipos also ???
If you're looking at 5000mah lipos, 1C charge rate is 5amps, the Accucell-6. like many chargers priced below $140 has an output of 50watts. You'll be able to charge a 2S at 1C since its below 50watt output of charger. A 3S will not charge at 1C since the higher voltage requires more power than charger can output. 12.4v X 5amps = 60.2watts.
This charger does the same thing all other 50 watt chargers do in this case - it limits charge current to stay under its 50watt limit. It will charge a 3S, but at something less than 1C - main difference - it will take more time to charge.
Most of these 50watt charges will charge up to a 6S lipo - but at reduced charge rates due to charger power output limitation.
Thanks for the help.
What about some power supplies under $70 that will get the job done.
Here you go - Pyramid is my recommendation as well - cheapest I've seen it -
the 200 is 20amps and 300 is 30amps. Either will be more than enough -
http://store.buyreliant.com/servlet/...Pyramid/Detail
Hobby City has a US warehouse and by the time its all said and done with S&H, it costs $4 more to buy it from the US warehouse - just in case you don't care to do international shipping.
I've used mine enough that I've gotten over the amazement at how much it will do versus what I paid for it.
Can I buy the turnigy accuel-6 at any other website because I want to get it from a place in the US
Do you guys know if the 16A 14v DC Power Supply for Chargers is a good power supply since its only $40
What do you mean ?
