What is a good lipo/nimh charger?
#16
http://www.hobbycity.com/hobbycity/s...idProduct=7373
I don't have 1st hand experieince with that supply, but haven't heard anything bad about it either. I would expect it to be a good supply.If you get one let us know what you think.
#19
Both are DC chargers, you will need a power supply to run either one.
The Accucell-6 is a 50watt output charger. The Accucell-8 is a 150watt output charger - its 3 times more powerful as the 6, so it is more expensive. You will need a more powerful power supply to run the 8 than the 6 also - if you want to operate the charger at its full charge capacity.
#20
Do you know if a I can use a 14v power supply with the Accucel-6?
