-   -   Do I need a Voltage Regulator (https://www.rctech.net/forum/radio-electronics/260423-do-i-need-voltage-regulator.html)
hlpressley 12-15-2008 09:02 PM
Hey guys I have searched on here but have came up with mixed results. I am running a JR DS8711 for steering and a JR z9100T for throttle on my 8ight-B. I have the Losi 2000mAh 7.4V LiPo Rx. pack and my question is do I need a voltage regulator? I am not one to try to cut corners so if I need it that is fine however if I don't that is cool as well. Obviously I would rather not run one but I will to save the expense of replacing expensive servos. Please help if you can. Thanks
AreCee 12-16-2008 10:14 AM
You may or may not.
As most servos the JR is rated at 6V but it may tolerate more voltage and again it may not. I have fried enough JR servos using 6V or less that I would be very leery of dumping 7.4+ volts into it.
So to be cautious and if you are worried about frying the servo then I recommend the regulator. Also not all Rx can take 7.4+ volts.
