-   -   Help please LRP tc-spec speed control (https://www.rctech.net/forum/radio-electronics/256992-help-please-lrp-tc-spec-speed-control.html)
b1sissylala 11-30-2008 04:38 PM
how do I connect my LRP80750 sphere comp tc-spec speed control to my
LRP50850 vector X-11 stock spec 17.5 turn brushless motor ?
tats21 12-01-2008 03:42 AM
you will c the letters on the speedo that say a,b,c follow the wires and soder those wires to the motor the motor will have a,b,c on it to
Toh WL 12-03-2008 07:49 PM
If it's a Novak ESC it will be written. So you can match the cables with the labels on both end.
I am using TC-Spec too with Vector X-11 3.5, this is what you should obseve,
Motor ESC
A = blue
B = yellow
C = orange
You can't get wrong with this simple configuration. Unless if you are color blind.
Hide 12-05-2008 05:53 AM
I am colour blind a bit and I blew up my Sphere :cry:
Toh WL 12-06-2008 07:37 AM
That's real most expensive lesson. After all TC Spec is not cheap compare with others ESC.
