Futaba BLS352/ BLS351 >
Old 11-23-2008, 09:25 PM
wstuart's Avatar
Trader Rating: 117 (98%+)
Default Futaba BLS352/ BLS351
Just wondering if you guys like these servos. Im putting a 352 and a 351 in my rc8 for steering and throttle. Ive heard that the brushless motors dont have as much holding power - wondering if its been a problem for anyone
wstuart is offline
Old 11-23-2008, 11:13 PM
rpm1968's Avatar
Trader Rating: 18 (100%+)
I have been running 352 for both steering and brake in an MBX6 and they seem both fast and strong. 1600mah rx pack / Futaba 4PK
rpm1968 is offline
Old 11-24-2008, 05:48 AM
Trader Rating: 24 (100%+)
good choice. I just ordered another one myself.
http://www.carolinasrc.com/Webstore/...idproduct=7407
I think it has 208 ounces which is plenty even for a truck. I also used carolinas special for 10% off. Not sure what it ended up being....
I think once in your cart it will be $139. So it ended up being about 125 shipped to my door.
ABURTON is offline
Old 11-24-2008, 05:56 AM
blktransam's Avatar
Trader Rating: 59 (100%+)
I run the 351 and 451 with no issues
blktransam is offline
Old 11-24-2008, 07:24 AM
hambone's Avatar
I use the 351 for steering duties in my 8t. Love it. More than enuf power. Getting a 451 for throttle this winter to replace a 3 season old 9451 that has been flawless.
hambone is offline
Old 11-24-2008, 09:58 AM
Crim3Wav3's Avatar
My BLS351 has a bad case of Parkinson's....i.e. it hunts for center whenever there is no load. Probably should send it back.
Crim3Wav3 is offline
Old 11-24-2008, 10:14 AM
rpm1968's Avatar
Crim,
Is that your steering servo?
rpm1968 is offline
Old 11-24-2008, 02:46 PM
Tiggertrucks's Avatar
Trader Rating: 59 (98%+)
same here i love them
Tiggertrucks is offline
Old 11-24-2008, 03:18 PM
I run them both also, and so far they are great. They center really well. No longer have the hunting sound from either servo when once they are powered up. Very responsive servos. I am running a 4PK too and have the Radio set up to run the higher/faster output and no troubles at all. I will continue to run em........
SPEEDSKI is offline
Old 11-24-2008, 03:40 PM
jamminnay's Avatar
my buddy has ran them all year with no issues.. i have been trying to decide between these and the ace servos
jamminnay is offline
Old 11-25-2008, 08:59 AM
Crim3Wav3's Avatar
Originally Posted by rpm1968 View Post
Crim,
yup, steering...in an 808. Bought new when i put it together at the beginning of the season. Was fine for about 3 weekends, thewn went to shit. It still feels fine on the track, but on the box, it's a little annoying (and embarrasing )...
Old 11-25-2008, 09:53 AM
R/C Tech Elite Member
JayL's Avatar
those futaba's are top, they run cool as well. I run 2 bls451 in 1/10 touring and 2 bls352 in 1/8 bugggy.
first time I 've had servo's last the whole season in 1/10
for less $ the ace/Associated are very nice. I have one for backup, I may run it for throttle as it is faster than the 352
JayL is offline
Old 06-09-2011, 05:58 AM
Default bls 351
hey guys i just buy 2 bls351 for steering and throtle for my mp9, but i have a noise when i hold brake, the setup on servo is ok, i have 4pk,its normal this?
the throtle and the steering is ok, no noise,any suggestion?ty
spiretos35 is offline
Old 06-09-2011, 09:05 AM
KThatcher's Avatar
Trader Rating: 64 (100%+)
Check your endpoints.. the brakes should stop the car but there should still be some play on the throttle return spring.. and at full throttle you should have a little play in the carb..
KThatcher is offline
Old 06-09-2011, 09:10 AM
IMO, hearing noise while holding the brake ist totally normal.
Andi
andreas78 is offline
