-   -   Adjusting timing (https://www.rctech.net/forum/radio-electronics/255178-adjusting-timing.html)
mizeracing 11-21-2008 07:25 PM
Adjusting timing
Does anyone know if the timing can be adjusted on a Novak 13.5? if so how. Thanks
Dragula426 12-29-2008 12:11 PM
If your using a speed control with programable timing, yes. Tekin RS units you can put the timing where you want it.
trickedyfz450 12-29-2008 03:32 PM
Are you talking about tuning the timing on the motor itself? if so then no not with Novak.
Warhawk 1 12-29-2008 03:38 PM
Thats strange because you can on the Novak 17.5. I have one and have advanced it as far as can be done mechanically.
not home 12-29-2008 03:39 PM
dont you just unscrew the three screws on the back of the motor and twist the can?
trickedyfz450 12-29-2008 03:43 PM
I am not sure with the 17.5 but I know my 6.5, 5.5, 4.5 don't.
trickedyfz450 12-29-2008 03:48 PM
I think that the novak ss models may have a timing adjustment.
Warhawk 1 12-29-2008 07:32 PM
Yep.
bkspeedo 12-30-2008 08:14 PM
Loosen the three screws on the back where the sensor wire exits, turn the plastic ring counter-clockwise until it stops (about 25deg), tighten screws. It may be a bit difficult as the sensor wires can cause the ring to not move easily. Try pushing the sensor wires into the motor some to provide slack so the ring will turn. All the SS motors have this ability. I'm not sure about the older motors.
