work on my M11?
what is the best place to send my M11 to have it fixed? it isn't powering on and I can't seem to figure out what's wrong...
:confused: |
You may not need to send it in... if you're using rechargeable cells in the transmitter and you charge through the charging jack in the transmitter handle, that might be your problem... the M11 has a switch in the charging jack that prevents the radio from being turned on when the charger is plugged in. Sometimes this switch gets stuck and prevents the radio from turning on even after the plug is removed.
Try plugging the charger in and unplugging it a few times. This sometimes solves the problem completely. |
what also might have happened:
the tiny smd-fuse (white "bug" located on the epoxy near the charging jack) is likely to pop when charging your M11 with the delivered charger. :flaming: always remove your batteries to charge them! regards, 666 |
| All times are GMT -7. It is currently 10:43 AM. |
