-   -   eZRun ESC problems (https://www.rctech.net/forum/radio-electronics/253246-ezrun-esc-problems.html)
Flatty 11-11-2008 06:52 PM
eZRun ESC problems
I got a new eZRun ESC for my slash the other day, and I am having some issues setting this up. I got the car running, but I have no idea how to set up the program card. Do I have to have a receiver battery for this? If not, can you give me some input on how to set this up?
Also, can I run a brushed motor on this setup?
Dima
lutach 11-11-2008 07:03 PM
Dima
Connect your ESC's Rx plug into the appropriate place on the program card. Connect your battery to the ESC and turn it on.
JeromeK99 11-11-2008 09:39 PM
The eZrun ESCs do not run brushed motors. The programing card also is used for the XeRun series that does handle brushed motors.
Jerome:tire::tire:
Drifting101 11-12-2008 01:59 AM
You plug the esc into the one labeled (ohms)+- then you plug the battrey in
Flatty 11-12-2008 01:20 PM
Thanks guys. Now I know I have to plug it in, and THEN plug in the batttery... I had that part backwards last night. WIll try it tonight.
Also, does anyone know what to do with the fan if I run a 3cell lipo? I was told to hardware it to my receiver?
Dima
Drifting101 11-12-2008 10:27 PM
If you run 3s run you fan off of you receiver
Flatty 11-13-2008 06:45 AM
I got it going last night... DAMN talk about FASTwith the 3 cell. Buut I am having a problem with reverse. It has a massive delay going from stop to reverse. In order to get it into reverese,I have to stop the car, and then pres reverse. Then I let the controller go into neutral. At THAT point the car starts going in reverse. The cr will not engage reverse while I have teh throttle in the reverse direction. Is there something wrong with this?
DIma
lutach 11-13-2008 09:00 AM
It's there to avoid any damage to the gears as you don't want reverse to engage when you are still going forward.
