-   -   Ice charger ??? (https://www.rctech.net/forum/radio-electronics/252858-ice-charger.html)
newbie67 11-10-2008 08:05 AM
Ice charger ???
New to the hobby and I'm setting up the Ice for a Team Check point Lipo 5400 not sure on the settings :confused: Some help please!!
1.Lipo 7.4V 5400 Mah
2.chg current: 5.4
3.dchg current: ?
4.dchg volt: ?
5.cut off temp: ?
6.max chg capa: 100%
crazy4wdracer 11-10-2008 08:11 AM
Charge at 5.4 Amps.
Don't worry about discharge current or voltage, you don't need to discharge a LiPO.
Don't worry about cutoff temp, the temp sensors can only be put on NiMH batteries.
Put max charge capacity at 90 or 100% and Charge in CC-CV mode.
newbie67 11-10-2008 08:15 AM
I've updated my question, now on the the other three just set to 0 :confused:
FOXY923 11-10-2008 09:11 AM
What ever they are set at is fine since you won't be discharging anyway. I would set the higher than you would actually want it to discharge to ie 3v/cell. That way if it does go into discharge you won't kill your battery by over discharge.
You can use the temp sensor. I use it on my orion packs. Set at 90 deg. Never been close to shutoff at that temp.
Duster_360 11-10-2008 10:28 AM
The temp probe on the Ice is pretty poor for batt temp anyway - it lags behind actual temp pretty badly. I've always had to set mine 15-20F lower than the actual temp I wanted it to use as a cutoff. I used raytech gun for reference temps and Ice probe was consistently low, too low.
This was made even mor eobvious when I got temp probe for my Hyperion 0610iNet charger - the response is much better and floows temps indicated buy my raytech gun within 3-5F.
