-   -   IPC v7.1 problems (https://www.rctech.net/forum/radio-electronics/245942-ipc-v7-1-problems.html)
D-Rock426 10-05-2008 04:55 PM
IPC v7.1 problems
i have a losi xx-t. i had it for a while and i just decided to try and get it running again. its the adam drake edition so it's all race ready (well it was back then). i hooked up a battery to it today and the ESC (ipc v7.1) turned on LED's functiond but when i hit the throttle it didnt move. it was green when i hit the throttle and went blank when i let off, not sure if thats normal. would you say the esc is bad? i really want to get this car going and i hope its not fried or anything. if anyone can give me some input that would be great, thanks
jbmx4life 10-08-2008 06:35 PM
I would be willing to bet that you might have to "set-up" the speed control if it hasn't been used in quite sometime. If you need directions let me know as I have a 7.1 and still have the directions in the box.
D-Rock426 10-09-2008 07:45 AM
haha yea thats what i thought it would need. if you can give me directions that would be great I appreciate it.
jbmx4life 10-11-2008 08:51 PM
Sorry it took me so long to get back to you....
See HERE for the directions on how to setup the v7.1 speed control. I found that and it is exactly the same as the directions I have. Saves me time from typin it all out too :D
