Do digitals servo's work with 3PJS?
Hi,
I have a Futaba 3PJS readio and R113iP Rx and would like to know if it is ok to use Futaba and Hitec digitals servos with it and if so can you mix and match with say a Futaba S9402 for throttle and a Hitec 5985MG (5965) digital servo for steering? I know that I won't be able to get the high response as the radio does not have HRS, only PCM or PPM. Cheers |
yeah, digital servo's will work with pretty much any radio. you shouldn't have any problem at all running them with you're radio. mixing and matching them won't hurt either. just make sure the servo's wires are in the correct order for the receiver and you're good to go.
Cool :cool:
