Spektrum rec. Futaba servo compatability ques...
naw, that should work fine.
Depending in the Spektrum RX that you have, it should be labeled on the receiver case +, -, and S for signal. I dont remember if the original gray case receivers (SR3000) has that labeled on the case, but from the outside of the case towards the middle, it goes Black, Red, White on that RX. Click here for the list of Spektrum Receivers, you can see they are marked with what color wire goes where.
