-   -   LIPO??? (https://www.rctech.net/forum/radio-electronics/240513-lipo.html)
GRIMREAPER 09-03-2008 09:25 AM
LIPO???
hello i would like to know the pros n cons about the lipo
and if u need to use a certent speedcontrol and how much more play can you get out of one then a regular pack
Duster_360 09-03-2008 09:41 AM
Pros - much lighter, longer run time, better performance (maintains voltage at higher level longer than all but the best NiMH race pacs),
Cons - more expensive than avg NiMH pacs, especially high quality cells, needs special charging protocol, CC/CV and a balancer to balance cell voltage. There may be more - these are the obvious ones that come to mind.
I started using lipo in 18th scale, best example I can give. Run time with GP 1100mah cells 9 to 12min. Run time with 1200mah lipo - 18 - 25min. Plus now, I can get a 1600mah lipo that will fit in the same space as the 6 cell pac used to go. I can also fit a 3S (11.1v) lipo if I want to do speed runs.
As far as esc is concerned - volts are volts. Where esc does matter is lipo needs a low voltage cutoff to avoid overdischarge which damages/destroys cells (depending how severe) and some escs have it (almost any brushless esc will have a lvc) where few brushed esc have it. This is getting better all the time - some of the newer escs let you run either brushed or brushless and have lvc. There are separate add on lvcs availabe too.
GRIMREAPER 09-03-2008 09:49 AM
i been thinkin about it i got a roster and 2 55ts on my crawler im just looking for better play time
RCabcs 09-03-2008 10:43 AM
since this has been so widely and endlessly discussed in a ton of threads, how about using the SEARCH button in the upper righthand corner of the page
and maybe not start 3 seperate discussions asking the same exact question
Duster_360 09-03-2008 12:47 PM
You'll get better run time, but you'll have to have a lipo capable charger and the lipos may not be cheap depending on how much voltage you need.
