Probably a dumb question
Whats the big difference between a 1400 and 2000 marked reciever pack? Whats the difference in run time? The reason why I am asking this question is because I am gettin ready to by a 1/8 truggy. I know I want a 6v but what pack should I buy. I am lookin to race once I get use to the truggy.
The only difference between the packs is runtime. It also allows you to safely charge the pack at a SLIGHTLY higher rate but with reciever packs it's not that important. The 1400 would be fine IMO because if you plan to race you most likely will never run more than half an hour or 45 minutes(depending on where you race) without having time to recharge your pack.
k thanks very much for your help.
| All times are GMT -7. It is currently 02:02 PM. |
