12V Power Supply....????
This may be a dumb question, but can you use a car battery charger (like the ones from Sears), to power your DC Lipo charger?
Maybe... the current won't be as clean as a dedicated power supply. We did this in the old days when using NiCads.. they were a lot less fussy than delicate LiPo batteries.
Best advice is to contact the maker of your charger.. they will probably not recommend it if using such a power source would damage the charger or cause it to malfunction. You can get a new or used power supply in the neighborhood of $40-$50. I have had some over the years that have gone through several generations of chargers.. Good luck! Jerome :tire::tire: |
| All times are GMT -7. It is currently 02:19 PM. |
