In line ESC LIPO cutoff ? >
Old 08-04-2008, 04:29 PM
Good Beer's Avatar
Default In line ESC LIPO cutoff ?
I'm looking for a in line lipo cut-off to use with non lipo ESC's. I've heard somebody makes them to cut the ESC off at the critical LIPO 6volt cutoff point. Anybody heard of them ? Got any idea where I can get one ? Thanks.
Good Beer is offline
Old 08-04-2008, 04:37 PM
Super Moderator
Grizzbob's Avatar
Well, if I understand your question right, then Novak does make a Smart Stop device that can connect inline with ANY ESC(& can also be used with Nitros, I believe) & prevent a battery from overdischarging....
Grizzbob is offline
Old 08-04-2008, 05:22 PM
FOXY923's Avatar
Check out this LIPO SHIELD from Common Sense RC.
Specs:
Model: LipoShield
Specifications: Input voltage: 1s to 12s Lithium or Lithium Polymer
Cutoff voltage: 3.0V/cell
Weight: 3.5g/.13oz
Works with all ESCs
Applications: Any plane without an effective lithium cutoff.
For $20 and 1s to 12s seems like a better deal then the Novak. I just ordered one from my LHS. I'll post a review once I get it.
FOXY923 is offline
Old 08-04-2008, 05:34 PM
I used the Novak 2S Smart Stop with my old Tekin G-10 and it worked just fine. Only hassle is all the extra wires and LED.
AreCee is offline
Old 08-05-2008, 05:01 AM
Good Beer's Avatar
Thanks guys, I'm just wondering if the "Soft stop" prior to hitting 6 volts would effect the end of a run instead of cutting of right at 6 volts. Hmmm, something to think about.
Old 08-05-2008, 06:41 AM
FOXY923's Avatar
Unless your not topping off your pack after each run you shouldn't even need the cutoff for racing. Bashing, yes you'll need it but a soft cut off shouldn't matter then.
FOXY923 is offline
Old 08-06-2008, 04:38 AM
Drifting101's Avatar
If you run a lower capacity lipo that wont last two races get one just in case of problems like the power goes out like at my track or you simpaly just forget
Drifting101 is offline
