AIRTRONICS/SANWA M8 FATAL ERROR >
Old 08-01-2008, 07:30 PM
Default AIRTRONICS/SANWA M8 FATAL ERROR
Hi just want to ask if anybody has a fix for a fatal error warning in ther m8, radios? any help wold be really appreciated. got this error when i enabled the ABL function everything seems to work fine except when my batt went low and restarted my tx. THANKYOU IN ADVANCE
tigs85 is offline
Old 08-01-2008, 08:01 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
That's a new one on me and my M8 is ten years old now.
wingracer is offline
Old 08-06-2008, 01:39 AM
Default M8 FATAL ERROR
Yup problem is quite rare, but read a few ones who had same problem, but no luck in finding a resolution to this hope some one would be able to help out...
tigs85 is offline
Old 08-06-2008, 04:26 PM
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
http://www.ifi.unicamp.br/~epiovani/M8.html
Is this what you did to enable the ALB on your M8?
FREELANCE_RCer is offline
Old 08-07-2008, 12:10 PM
Default Fatal error
Yes sir thats exactly it... did not mind the disclaimer much, thought everything would be ok as long as i follow the steps exactly i was able to activate the alb and i was even able to set the alb parameters and it worked fine, turned off the tx and after about an hour and when i turned it on again fatal error message displayed. i can still get to ths system settings but no matter what i changed or reset it does not do anything. I always wanted to have a radio with an abs function on it thats why i tried the steps....my mistake shouldn't have done it
tigs85 is offline
