need recvr advice
I have a Micro 555 dual conversion FM reciever that, when the circuit board is in the case, has no more than 5-6 feet range with xmtr antenna down. If removed from the case Recvr seems to work intermittantly with great range.
If I extend the Xmtr antenna, reception is fine, in or out of the case. Suggestions at to the cause of this problem would be greatly appreciated Thanks, Danny M |
Doesn't seem to me that you have a problem. AM & FM radios need the antenna out for proper operation.
If you don't want to have the transmitter antenna way out then get a 2.4GHz system like a Spektrum. |
| All times are GMT -7. It is currently 12:53 PM. |
