-   -   Brushless EPA Question (https://www.rctech.net/forum/radio-electronics/229518-brushless-epa-question.html)
Drifting101 06-30-2008 02:05 AM
I want to run a 4.5 novak velocity light in a T4 but i am worried it will be too much sometime so if i turned down the Throttle epa will i need to change gear ratios and does it damage the motor?
And if it matters i will be running a GTB and 3pk with it
RedBull_81 06-30-2008 06:43 AM
I recomend you start by running the Novak recomended gear ratio in your T4. And no, turning down the throttle epa will not hurt the motor at all.:tire: Link to Novak gear recomendation chart:http://www.teamnovak.com/tech_info/b...r_gearing.html By the way, GTB & 3PK, good choice.;)
Drifting101 06-30-2008 11:08 PM
I dont think that i got my question across properly. I have a gear ratio set up but IF i turn my epa down will it effect the ratio "needs"
Drifting101 07-03-2008 03:50 AM
Anyone??
dethklok151 07-05-2008 08:06 AM
no need to change gear ratio .all you are really doing is limiting top speed.however the esc may get slightly warmer as you will be running at part throttle instead of full throttle.the esc does a little more work at part throttle,at least that was the teory back in the day ,it might have changed some with brushless motors.i used to turn the epa down on my mamba back in the day,no worries.
Drifting101 07-05-2008 08:30 AM
Cheers guys
