endbell to 180deg
guys, what happens when i rotate the endbell of modified motors to 180deg?
what will change? speed? torque? rotation? im planning to run the motor in reverse and as i know, forward & reverse has different speed. please help! |
I believe...
I believe it will run backwards for you. Why not just try it and see?
Originally Posted by bryanleec
(Post 4430361)
or....
Originally Posted by todd8603
(Post 4433498)
thanks todd,
Maybe someone here have tried this and what are your observation guys? Yup i tried swapping the wires but the speed is slower. and yes i tried turning it to 180 deg.. and i dont know the difference :confused: please help. thanks! |
Turning ther endbell 180 degrees will reverse the rotation, but the timing will then be wrong.
Turn the endbell 180 degrees, then advance the timing by turning the endbell about 12 to 20 degrees clockwise from the zero mark. THen you'll have reverse rotastion AND the right power. |
Wow, thanks for the advice!
i really have poor understanding on timings but all my rc's are electric. I dont really change timing. thanks man:smile: |
| All times are GMT -7. It is currently 01:25 PM. |
