-   -   m8 and sidewinder (https://www.rctech.net/forum/radio-electronics/220420-m8-sidewinder.html)
razataz 05-04-2008 07:16 PM
m8 and sidewinder
does anyone have a problem getting their m8 to work with the sidewinder esc my other radios work fine with the esc . the m8 has the spectrum my other two are fm. m8 will not read neutral unless you turn the epa brake down to 72% then the esc goes crazy.
Zerodefect 05-05-2008 04:56 AM
My M8 settings on epa are at 110% forward and brake.
If I remmember right I set my mamba max by holding full throttle, then full brake at the red led, then nuetral at the yellow.
Is your esc not retuning and accepting the nuetral during setup, or is your radio not returning to nuetral? Deos the car keep driving even when you let of the trigger or something?
wyd 05-05-2008 05:23 AM
I always start with my full Throttle EPA and brake EPA at 100% when setting my Sidewinders and Mamba Maxs.
Sounds like something is not exactly setup right for you. I know on the Futaba radio I needed to reverse my throttle servo to setup my speedo. I can't remember if I needed to do that on my M11. I will have to check that tonight when I get home from work this evening.
razataz 05-05-2008 04:17 PM
How do I get the trigger back to nuetral on radio.when I set sidewinder if I pull trigger fowerd just a tad it will set nuetral. after it sets and I let trigger go it will take off .
